Cleaning the interior - roof
galerie
What would be the best approach to clean the interior roof of a vehicle. Mine is tan in color and its dirty. I know alot of people say to stay away from water because it will make the adhesive less sticky. Any suggestions from all your pros.
Thanks
Thanks
I'm not sure there are a whole lot of ways to clean this. Here in NC, detailers are not allowed to touch the fabric / padding on the roof. They say it has something to do with fire protection.
Personally, I just wet a MF with a mild cleaning solution, such as watered down 3:1 or 4:1 carpet cleaner (after I mix a batch of carpet cleaner from the concentrate I use a portion of that mix and add in 3 or 4 parts water). I then press the MF into the ceiling and hold it there for a min. I do this for one section at a time blotting up the dirt. Rarely will I rub at all as the fabric is very delicate. I have had great luck with Bissell carpet / upholstery cleaner from wal-mart. The stuff in the blue container, or green for hypoallergenic.
I have only had to do this a couple of times on different vehicles I have. After, I tape off the trim and spray ScotchGuard fabric protector on it, two coats. After the scotch guard, I have never had to clean the ceiling again.
Vacuum well to start. Then wipe with a damp MF, well diluted with a mild cleaner like Woolite. Let dry and inspect. Do not over wet.
