Burningcoals
I use 105/205 with a DA. I use CG foam hex pads. Black for polishing.
I am always searching for what to use on black cars/bikes after 205 Polish, when the paint is pristine.
Lately I have been using Opti-Seal, and every 2 weeks using Meguairs Ultimate Liquid Wax. This process works to completely eliminate micro swirls and keep them gone under a light.
So last week I tried Menzerna 4500, and saw some micro swirls, then tried Menzerna Top Finish both using red super fine foam pad and black pad and DA with little to no pressure. Trying to glaze and jewel as it would be. I failed, and had to re-do 205, then use Opti-seal. I just cant find anything that doesn't micro swirl after 205.
So this week I decided to try Black Light after 205. Again, red pad, no pressure, lowest speed just enough to cover the surface, wait 15 minutes and use a super fine micro-fiber to remove. Came off easy. But, swirl city.... Again had to strip and re-do with 205, and then just threw on Ultimate Wax, and it looks pristine again.
I would like the deepest possible black shine, should I move to a carnuba? will it be too much on soft clear coats? I think Ultimate Wax works wonders because its super easy to apply and remove with no abrasive.
