hacadacalopolis
About 2 years ago I undercoated an s13 240sx dash. There was severe heat and sun damage which caused splitting all the way down the foam. to the plastic. Its an alternative to make an immitation vinyl look-which can be painted. The texture can be reduced with reducer or a thinner.
For the cracks, Cheap epoxy at lowes was used Loctite A & B. Was filled, Let SET. Then skim coated with added baking soda or talc powder mix to epoxy for fine sanding.
Rest of the Dash was sanded with 180 grit then shot with cheap dynatron rubberized undercoating.
$15 epoxy
$60gal Dyna-Pro $30 30oz
$15 epoxy
