imported_Luster
This would really fall in the category of "Vehicle Maintenance" rather than detailing. But I thought it would be helpful.
I would highly recommend this "mod" (Haha). I call it a mod because hardly anyone ever does it!!! ;D
I have been having some pretty bad smells coming through the A/C vents. Someone told me to change the CA filter because it can collect mildew, mold, dirt etc.
I'm actually embarassed to show the the "before" pictures. But here they are!!!
Open the hood and remove the two plastic clips that hold down the plastic cowel cover.
Pull the wiper back and carefully pull the cowl cover up on the windshield.
This will reveal another black plastic cover that seals the Air Filter.
Remove it. (no hardware to remove)
The removal of the plastic cover will reveal a (most-likely) NASTY Cabin Air Filter. Mine was fill of dust, dirt, pollen, BLACK MILDEW, mold, leaves, etc. I bought the car about 9 months ago and never changed the filter! (lesson learned).
Now replace the CAF into it's position, making sure it "snaps" down into its casing.
I cleaned the lower cover with Tire Foam (I use TF for everything plastic or rubber. Has some pretty good cleaning power!) Then put it back in place.
I then replaced the cowl cover and snapped in the plastic clips to hold it in place.
Once everything was back together I sprayed some PB B&B Tire Dressing on a pad and wiped down the black cowl and rubber seals to give it a finished look.
And the money shot.
A/C now smells like sweet fresh air!!!
And the money shot.
