driving impress said:I have used both. They both have there pros and cons. I personally like the steam machine because it is much more versatile. I use it for the entire inside and some on the less dirty engines. As for carpet cleaning, you will still have to scrub a little then go over it with a wet/dry vac. The extractor is easier for larger and much dirtier carpets. Below is a link that might help. Also is the link for the steamer I use. Since using the steamer on the entire inside, I have greatly cut back on cleaning chemicals. Good luck, hope this helped.
Detailing Vapor Steamers | Using Vapor Steamers For Auto Detailing Compared To Carpet Extractors
Steam cleaner, steam cleaners, steam cleaning, steam vapor cleaners
I have the TR-5
MI2 said:Does the TR-5 vacuum up the debris from the steam?
driving impress said:No, you have to vacuum before you steam. There is a couple of options on that website that do have steam/vacuum. The Gaia is about $850 and the Desiderio is about $1300 and well worth it from all I've researched and read about it.
