forrest said:
High quality billet will show the results of less than prefect technique.
The most flaw-free finish I've found with billet comes from using a high quality polish with a rubber nitrile glove. I'm guessing it's your applicator or removal towel that's causing the marring you see. What are you applying and removing with?
Try putting a nitrile glove on and scooping a little polish on to your finger tips. Rub a small area until the product turns sufficiently black, then wipe away lightly with a new, quality, microfiber towel. Do not let the polish dry, and do not use lots of pressure.
Let us know how that area comes to the surrounding area. BTW, I'll put our Billet Metal Polish up against any other polish made. And, there's no such thing as a non-abrasive metal polish.
My report - major success! Used my hand, in nitrile gloves to apply Mothers Billet Polish (man, is that expensive), removed product with a clean MF towel and practically all the marks are gone - it's very near a mirror finish - I'm sold on this process.
By the way, I tried the Mothers product on my real (Halibrand) magnesium wheels (cobra replica) - just on a small section and it appears to work as well. Also, it's my understanding....
From
How to polish aluminum wheels
"But first, if they are magnesium alloy (mag alloy) you can forget the polishing bit unless they contain less than 20% magnesium. I don't care what any other polish manufacturer tells you. Magnesium is white and will not polish. If anyone tells you they have a mag alloy polish, it's an aluminum polish. Your mag wheels will come clean with a wash, and if you have used an acid or they are oxidizing you can clean them and remove the oxides with polishes, but magnesium doesn't shine."
So, Mothers has a Mag & Aluminum Polish - is it, therefore, really only an Aluminum
polish since magnesium can't be polished or do you disagree with the above statement? Is it also true that since magnesium doesn't polish, all one is doing is cleaning them, even when using your product? If the above statement is true, what is the best 'cleaner' for magnesium wheels? Thanks.
