dolfans- I'd switch back to the previous pads (assuming you liked their performance).
I used waxes on wheels for ages before products like Coatings and Sealants were available. Some waxes work absolutely fine for this and don't have any "oiliness retaining dust" issues. Collinite's 845 Insulator Wax comes to mind.
Sealants generally work better for this and last a lot longer. Many coats of Klasse Sealant Glaze was my go-to for years.
I now do wheels with FK1000P (IIRC, it was renamed BWM1 or somesuch). No problems, lasts for a very long time as long as I clean with (strong) shampoo mix instead of Wheel Cleaners.
Some coatings will last a very long time and shed contamination readily. If the application doesn't bother you, that's probably the way to go, but I'd sure research it to make sure your choice will really last that long. I got years out of OptiCoat v1.0 and considered that worth the hassle of application. Nothing I've read about since then has sounded as good, so I just stick with the FK, but that's just me and if somebody has suggestions about an excellent Coating, I'd pay attention and give it some strong consideration.
The last time I bought a Coating for wheels (PPLE brand) it dried out before I got around to using it, so if you go that route I wouldn't leave it on the shelf for too long.
