Bunky
Detailing Gnosis
Blackfire Trim and Tire Sealant Review
I received this product in a AutopiaForum giveaway with a condition for a review. This was a new product to the Blackfire line and available in two sizes: 4 oz and 8oz.
Claims:
BLACKFIRE Total Trim & Tire Sealant is far more than a trim dressing. This polymer-based trim restorer forms a bond at the molecular level, restoring the surface while coating it in a durable, protective shell. BLACKFIRE Total Trim & Tire Sealant doesn’t wash off in the rain – it actually causes water to bead up like a wax! Treated surfaces will have a factory-fresh appearance – not a sticky, greasy mess like other so-called trim restorers.
Price: $19.99 for 4 oz, $29.99 for 8 oz.
Product
For this review I decided to compare Blackfire to my usual go Ultima Tire and Trim Guard (old version) which is my most used trim product. I do not use trim products on tires but did for this review.
This product was used on a 1997 Dodge Dakota. I cleaned the surfaces with Mothers Back to Black Heavy Duty Trim Cleaner that I like a lot over typical cleaners since they gel consistency stays on the surface.
The mirrors and door pulls are molded out of a rigid plastic. The cowling and front facia below the bumper are much more flexible.
Side by Sides with control swipe
Right mirror- day of application
Left mirror - day of application
Both mirrors -day of application
Cowling
Door handle
Front Facia
Beading pics 3 weeks later
Cowling
Tires at application and 3 weeks later Blackfire is on the right
Usage notes:
Scent: Pleasant on contrast to original forumla Ultima's chemical smell
Consistency: Thick creamy consistency. It is definitely not as oily as Ultima
Application: On the hard plastic mirrors and door pulls, it was more difficult to get an even appearance compared to Ultima. This can be seen in the images.
Ultima definitely spread better and gave a more even look initially. On the softer plastics such as the cowling and facia, there was not really much difference but Ultima had the edge in quick even application.
On the smooth surface Michelin tires, I could not get either to really look even. I have trouble with other tire dressings as well. There is something about the very smooth rubber that resists dressings. I suspect silicones in dressings give a more even look - my theory.
Final appearanceBlackfire tended to darken plastics much more than Ultima. The uneveness did disappear for the most part after several days. As shown in the rain pics, Blackfire tended to bead better and stayed darker,
Pros:
1. Nice scent with no chemical smell
2. Nice darkening effect on plastics
3. Gel consistency - not oily
Cons
1. Not as even coverage initially on some plastics. This is not uncommon with other trim products to behave different on some surfaces compared to others.
2. Price is slightly higher than Ultima ounce for ounce but Blackfire is available in a small size.
3. No help for my Dakota tires but neither was Ultima. I want to try Carpro at some point.
Summary
A nice addition to the Blackfire line.
Claims:
Product
Cowling
Door handle
Front Facia
Cowling
Usage notes:
Pros:
Cons
Summary
