Black Pearl Tire and Trim Armour Clear
rzatch
I‎ was offered a sample of Black Pearl Trim & Tire Armour to try and thought ‎I would share my opinion of it. This was not in trade for a review. I was ‎simply asked if I would like to try it and report back.
Product Claims:
Black Pearl Trim And Tire Armour
‎The 4 oz. bottle will coat 1 - 2 sets of average-sized car tires (or 1 set of SUV Tires) – ‎two applications.
Black Pearl tire Shine is a polymer-based 'permanent' tire shine composition. It is ‎best applied with a 2-inch high density foam roller. It forms a flexible, durable, dry-film ‎that is not tacky. One or two coats are recommended. Two coats produces a blacker ‎and shinier finish. It can be applied year-round (down to 50 F), and is not affected by ‎rain, snow, road salt, will not evaporate on hot, sunny days, and dust (including brake ‎dust) and particulate (under dry-driving conditions) will not adhere to the surface.
Omni Clean
Omni Clean is the manufacturer supplied cleaner and comes in a 32oz spray bottle; it ‎is a commercial sodium hydroxide/sodium metasilicate-based cleaner/degreaser. ‎Recommended products include: Purple Power, Super Clean, and Westley’s Bleche- ‎Wite.
Details:
‎Black Pearl Trim And Tire Amour
‎1.- Packaging : Plastic 4oz & 16oz bottles, 4oz has flip top cap
‎2.- Directions: Clearly labeled and included printed instructions
‎3.- Viscosity: About the same as popular tire gels
‎4.- Color: White, dries clear
‎5.- Scent: Almost non existent
‎6.- Price at time of review: 24.99 4oz, 74.66 16oz
‎7.- Manufacturer: Providential Coatings LLC, Made in the USA
‎8.- Roller and tray included
Omni Clean
‎1.- Packaging: Plastic bottle with trigger sprayer
‎3.- Viscosity: About the same as water
‎4.- Color: Clear
‎5.- Scent: Strong chemical APC
‎6.- Price at time of review: 32oz = $ 9.99
‎7.- Manufacturer: : Providential Coatings LLC, Made in the USA
‎Preparation:
•Tire surfaces should be clean, dry, and free of silicone oil (e.g., from other tire ‎shine products, and mold release agents on new tires), road grime, and brake dust ‎before applying this product to ensure proper adhesion and a desirable finish.
•Clean tires first with OmniClean or a similar commercial sodium hydroxide/sodium ‎metasilicate-based cleaner/degreaser. Recommended products include: Purple Power, ‎Super Clean, and Westley’s Bleche Wite (shown on the second website video).
•NOTE: Please review the safety precautions on the bottle before using these ‎recommended cleaning products.
•Spray the cleaner/degreaser on liberally and scrub vigorously with a soft-bristled ‎brush capable of getting in and around the tread line, and all of the raised ‎lettering/numbering, etc.(e.g., a stiff nylon scrub brush – auto parts stores sell brushes ‎designed specifically for scrubbing tires).
•A dark brown discharge indicates that silicone oil, road grime, and/or brake dust ‎IS present, and must be removed.
•Allow the cleaning product to sit on the tires for a few minutes, and then rinse ‎thoroughly with water with scrubbing.
•Note: Be sure to rotate the tires during cleaning to ensure that the entire tire surfaces ‎‎(i.e., including the portions initially facing the ground) are thoroughly cleaned.
•Tire surfaces are properly cleaned and ready for application when the ENTIRE ‎tire surfaces wet evenly, and are darker when wet (if in doubt, allow tires to dry, and ‎then re-wet).
•If the rinse water beads, and the tire surface does not darken when wetted, on any ‎part of the tire surfaces, the cleaning/scrubbing/rinsing process MUST be repeated ‎‎(See website ‘How To’ videos).
•Allow tires to dry completely before starting.
•NOTE: Failure to completely remove the oily residue from previous tire shine ‎products, or mold release agents, will prevent Black Pearl Trim and Tire Armour ‎‎(because it is water-based) from properly adhering to tire surfaces, which will ‎cause the cured films to start flaking off once the vehicle is driven.
RECOMMENDATION: A very effective way to determine if the tires have been properly ‎cleaned is to prepare a small Black Pearl Trim and Tire Armour test spot on one front ‎tire first (one coat), allow to dry, and then drive the vehicle a few miles. Inspect the test ‎spot. If the film is cracking, flaking, or is totally removed, the tires ARE NOT properly ‎cleaned.
Application: Black Pearl Trim And Tire Armour
•Apply with the included high density foam roller.
•If what look like small ‘craters’ (referred to as ‘fish eye’) start forming on the film while ‎applying product, there are residual tire shine products, or mold release agents, or ‎surfactants, on the tires, which should be removed. Quickly rinse product off before it ‎starts to dry, and refer to the ‘Tire Surface Preparation’ section.
•If a blacker and shinier finish is desired, apply a second coat. Wait for the first coat to ‎dry completely before applying the second coat.
•If two coats are to be applied on the same day, for added convenience, the un-washed ‎roller and tray may be stored in the refrigerator between coats for up to approximately ‎two hours.
‎•If this product gets on the wheel, or the body of the car, quickly wipe off with a damp ‎paper towel, sponge, or cloth. It will not harm these types of surfaces.
•Allow coatings to dry completely before using the vehicle. Dry time is approximately 30 ‎minutes depending on temperature and humidity.
•Do not expose a fresh coat to rain or sustained wetting, otherwise the film may ‎temporarily revert to the milky appearance.
•Driving with fresh coatings under dry conditions and/or exposing them to direct ‎sunlight, after they have completely dried, will accelerate the final cure process.
•If the coatings get damaged (e.g. scuffed on a curb), clean the damaged portions with ‎a damp nylon dishwashing scrub pad. Use the abrasive side to remove any loose ‎flakes of coating that are still sticking to the tire surface. Once the surface is clean and ‎dry, apply a fresh coat of product to the damaged portion.
•Clean fully cured coatings with OmniClean or a similar cleaner/degreaser, and a ‎sponge or soft cloth, and rinse thoroughly with a pressure washer or garden hose.
•A fresh coat may be applied directly over an existing film that is clean and dry. No ‎additional surface preparation is required.
CAUTION
‎•On warm days, do not apply under direct sunlight. Also, do not apply when tire ‎surfaces are warm. Also, do not apply under breezy/windy conditions. These ‎conditions will accelerate the dry-time, which may result in a more textured final film ‎and/or the formation of white spots (due to incomplete bubble dissipation) on the film. ‎An accelerated dry time may also have an adverse effect on adhesion and ‎longevity.
•Applying in an enclosed area, such as a garage, is recommended. For added ‎convenience, consider applying in the early evening and allowing to cure overnight.
•Do not apply at temperatures below 50 degrees Fahrenheit or a proper film may not ‎form. If in doubt, prepare a small test spot first, on one tire, to ensure best results.
As you can see preparation and application are pretty straight forward and easy. Just ‎like doing a sealant or coating on paint, surface preparation is key to good result, ‎BPT&TA is no different. A few extra minutes spent prepping will pay dividends in ‎performance of the product.‎
The Kit as it comes.
‎4oz bottle
Omni Clean
Consistency of the BPT&TA,
This is 15 drops. I ended up starting off with 45 drops to load the roller and ended up ‎using another 45 to coat all 4 tires with one coat. Directions state the 4 oz. bottle will ‎coat 1 - 2 sets of average-sized car tires (or 1 set of SUV Tires) – two applications. I ‎used nowhere near that amount. I also took my time and really worked the product into ‎the tire. I would estimate on my application I could easily double that. Even at my less ‎than recommended application amount the tires have a very nice matte/satin finish ‎which is the shine level I prefer.‎
Initial Cleaning Omni Clean making quick work of the gunk coming off the ‎tires. These tires also have had no dressing applied to them in quite a long ‎time. The Omni Clean is a very good cleaner. I have not tried it diluted this ‎neat. The way it cleaned I would expect it to still be quite a strong cleaner ‎diluted. Care should be used with this cleaner on certain wheels.
Second Cleaning. White foam indicates the tires are clean. Water lays flat ‎on the tire with no beading.
Immediately after application of Black Pearl, still wet.
After 20 minute dry time.
I consider this to be a satin finish. The tires were dry to the touch and had ‎no greasy feel to them.
Conclusion:
Does the product meet its claims? Time will tell on durability in the looks ‎column I say yes. Durability will be tested over the next month. The vehicle ‎it was applied to is washed almost daily so in the next month it will probably ‎be washed 20-25 times. About the amount a normal person washes their ‎car in a year, maybe a little less.
Pros:
Omni Clean
‎1.- Excellent cleaning ability
‎2.- For the amount used (very little) price isn’t bad.
Cons:
‎1.- Pretty strong smell need good ventilation
Black Pearl.
Pros:
‎1.- Easy Application
‎2.- Needed products supplied with order
‎3.- 6-8 month durability (claimed)
Cons:
None really, a little pricy upfront, but when considering the time and money ‎savings of not having to dress your tires or trim for months instead of after ‎almost every wash or rain storm, its very well worth it to me.
Final Observations and Summary:
Great product, good looks, easy application
Update:‎
This is after 1 month and two APC cleanings. No change in looks, still ‎holding strong.‎
Around the 3 month mark.‎
Over the next few months the tires were cleaned a few more times with ‎APC and degreaser. At about the 5 month mark the coating was starting to ‎fade and around the 6 month mark was pretty much gone. Considering the ‎abuse the coating was subjected to it lasted longer than the manufactures ‎claim. ‎
