I've been waiting for a while to test the theory that freezing bird poop will make it easier to remove. I came up with this in the early Spring when it was VERY cold outside (20 or so) and a flock of returning birds perched in a tree under which I was parked.
When I got home I started to remove the bonbs and noticed those that where on the hood (warm) were their usual hard to remove BUT those on the roof and trunk (very cold!) slid right off.
Keep in mind my car had several layers of Z2 to protect it through the winter.
So I figured the cold would cause something to happen to the poop bomb and make it easy to remove. I waited to get bombed and today I finally was. (Oh now there's something I never thought I'd hear myself say!)
There were two hits so I took an ice cube and placed it on one of the poop bombs and left the other untouched. When the ice cube was a about half melted I took a towel and gently wiped the bonb and it came right off as a whole without any resistance or residue! The other was dry and hard and well stuck to the car. I then used an ice cube on the second one with the same results, it slid right off.
So apparently the combination of the cold and the soaking from the melting cube does something to force the droppings to free itself of the polished surface.
Whatever the reasons... it works!
