polisher
any tips/ideas how to clean that "carpet" on the top. lol.
Most headliners are glued onto the backing foam, so if you over saturate the headliner it could loosen the adhesive and cause the liner to drop.
I use my steamers big triangular brush through a white towel (so I can see if I am removing dirt) all the time on headliners and it works great. Because I am working fast so I don't affect the glue, I can knock out the entire headliner in a few minutes. Just brush front to back, and try to keep the pressure the same. Never have had a problem with a headliner loosening, falling, etc..
If its just a small grease spot where some dirty mechanic's hands held on to the edge, etc., I will also use a little Meguiars APC + on a microfiber, work it carefully straight in, not sideways if possible, and blot it out.
Dan F
I, too, use a steamer to clean headliners. I spray a bit of APC on a terry cloth towel, fold it over the brush attachment, blast it with a hit of steam, and use the hot towel to clean the dirt from the headliner. I don't use a direct hit of steam on the liner except possibly for a brief second if the liner is exceptionally dirty.
