Had this for approx ten years Metropolitan Vac ‘N Blo (Vacuum / Blower Unit)
Look for a vacuum with a high number 'lift' (ins.wg) not HP as it only refers to motor size, or amps, which is current drawn
The Vac N'Blo Pro comes with a 12 ft power cord, a 6 foot flexible hose that can be attached to the intake or exhaust side of the vacuum (making it a blower), two 20 inch, extensions, a blower nozzle, Pick-All nozzle, dust brush, crevice tool, carpet/floor attachment, inflator adapter, 4 piece Micro Cleaning Tool Kit and 3 disposable paper bags.
Special features include an adjustable air control valve (Power Control) at the end of the hose that allows you to control suction and a carpet/floor attachment that is adjustable for carpeting and wood/linoleum/tile floors. This is the perfect vacuum cleaner for boats and RVs. It is powerful enough to clean up virtually any mess yet small enough to allow for easy storage. While the basic machine weighs under 10 lbs. (without hose), the Vac N'Blo Pro comes with a 4 wheel, hook and loop attached, trolley that allows you to pull it easily behind you.
Specification:
• Peak Motor Power: 4.0 HP
• Power Requirements- 11.25Amps, 110-120 volts
• Single-phase, 50-60 Hz VAC
• Vacuum: 95-inch water gauge static lift (this thing sucks LOL)
• Blower: 145,000SCFM @ 28,000FPM
• Dimensions: 15-iches long and 7-inch diameter
• 12-foot cord, re-usable cloth dust bag, and 16 accessories (crevice tool, brushes and etc)
