Battery Powered GARAGE LIGHT
oak3x
I have a detached garage, which unfortunately has no electricity. Does any know of a Battery Powered Overhead Light which would be bright enough to illuminate the inside of the garage. I currently rent, so I don't want to install electricity. Any suggestions would be greatly appreciated!
Dave
oak3x- He's not just being facetious ;) You really need a lot of light to detail and I can't imagine getting sufficient illumination from battery powered lights. You'd spend a fortune in batteries in the long run anyhow. IMO most shops don't have enough illumination even with scads of lights.
You might find some battery powered fluorescents, and you could supplement them with a bright battery powered worklight, but IMO it wouldn't work out all that well. No idea where to find the battery powered fluorescents, but I'm sure I've seen them somewhere...
If I were in that situation, and getting the garage wired or using extension cords really was out of the question, I'd get a generator. I consider adequate lighting to be the only thing that rivals a clean work environment when it comes to the essentials.
