wifehatescar
My L5-S1 is killing me!
Well, alot of people have been looking for my review on this, I won't name names [scottabir!!!], so here it is.
The product:
http://www.aztecproducts.com/Products/hotspotter/specs.cfm
I was looking a very portable, heated extractor that was relatively affordable and this fit the bill. Basically, there are two models:
1. "Spotter" -comes with 15' cord, 10' hose and clear suction head
2. "Detailer" -comes with 50' cord, 16' hose and stainless steel head
The detailer is about $30 more than the spotter. I paid $600 for the spotter plus $17 shipping. The extra hose/cord I figured would be too much too carry and I like the clear head better to see what you are sucking up. Buying direct is cheapest and you cut out the middle man which I think results in the best customer service.
The machine does heat the tank water to over 200 deg, you can feel it starting to boil just as the heater turns off. You have to run the spray for about 15 seconds first thing to purge the unheated water from the hose. The 1.5 gal is good enough for most cars unless you maybe have to do the carpets and fabric seats in multiple passes.
The machine is loud, I recommend ear plugs. You are only using it for 20 minutes maybe for a car so not a big deal. Basically, the machine does what is says it does. It will not heat and suck at the same time (if it did you would blow fuses). You let it heat up then switch it to suction. It will fully heat room temp water in about 15 minutes, very cold water (like 40*F) in about 25 minutes.
Basically, if you have any questions on the specifics, send me a PM or talk to Aztec
. I did not find any surprises though and am happy with the purchase. :dancin It's not the fanciest, most perfect machine ever or anything, but it does it's job cheaper than any other heated extractor I have found...
Dwayne-I tried to put this in the reviews section but there is no section that fits this product....
The product:
