advs1 said:
how do you vacuum the car with no generator? do you just use the customers electricity? i have a rigid battery powered vacuum i use for delicate situations
Great question........Vacuuming the interior is achieved using a 12v inverter, or I would just tap into an existing 110v outlet at the customers location if available. Using a battery powered vacuum is a great idea, just that from previous experience on rechargeable batteries is that their life expectancy is short, they eventually loose their charging peak and get expensive to replace.
toyotaguy said:
dave is this what you were telling me about? thats pretty sweet. most car wash people arent worried about swirling up the car, and those who are, are usually doing their own washing anyway!
I may have to talk some more about this with you tomorrow since this weather SUCKS!!!!!!!!!
Eric, that's the unit I have been telling you about........thanks for the good words on the Detailing Caddy....With this system, of course like any vehicle cleaning technique if it is performed properly with premium MF towels, using Poly's Detailing Fluid (Recommended and Approved) the results are incredible.....If you want to check it out and demo it, just let me know......I couldn't agree with you more on this weather, but look at the positive side of things, we are going to have a whole lot of work once the sun shines.
As you can see from the photo's below....its a win win situation for the customer and for me....
* Absolutely no scratches induced with this system if it is done correctly
* Conforms to City and County waste water discharge laws, completely rinseless process.
* Customers is completely satisfied with the results
Before shots of this black Bentley GT
Half of the hood cleaned with the Detailing Caddy process, no pressure washer needed for awesome results...
Hood finished off for perfect results....
As you can see in this photo I am towing my trailer which is completely outfitted with literally everything including my pressure washing system and water tank. Since this particular job in a coastal community at the waters edge, I utilize the Caddy as you can see fro the following pics.....
I just plug it into my 12v accessory outlet in the back of my SUV or the customer vehicle and wrap the 50ft hose around the vehicle, then get the job done and no water hits the ground that can lead to a storm drain.....Sure get a lot of :thumbs_up: from city workers and code enforcement!
Passenger side totally cleaned to perfection
Poly's detailing fluid being applied using the Detailing Caddy which atomizes the product for a fine application
Detailing fluid is wiped using a quality MF towel which is also in our bucket solution to ring out the dirt and debris from the initial wipe.
Finish off the process by buffing or flashing the residual moisture with a thick MF towel like this one from Towel Pros....and look at the results......
