I think I've narrowed it down to 3:
Craftsman 3 gal. Air Compressor, 1.5 hp, Horizontal Tank
Sears item #00915310000 Mfr. model #15310
Oil-lubricated compressor provides homeowners with a lightweight, portable source of air power for many do-it-yourself projects. Direct-drive, horizontal tank compressor delivers 2.4 SCFM at 90 psi.
$125
Makita MAC700 2 HP Air Compressor "The Hot Dog"
Roll bar handle for portability and added protection against harsh jobsite environments
High rated 3.3 CFM @ 90 PSI
The low 1720 rpm is half that of most competitive units, resulting in greater motor and pump life, and the substantially lower noise level makes it the quietest compressor in its class
Large cast iron pump with automotive style cylinder and piston deliver maximum performance
Oil lubricated for cooler running pump and an automotive style air filter for easy, low-cost maintenance
$153
Porter-Cable CPFAC2600P 2 HP, 6-Gallon Pancake Compressor
One-year warranty
2-horsepower motor provides 3.7 scfm at 90 psi and 2.7 scfm at 45 psi
High-pressure design keeps tank pressure between 120 and 150 psi
Higher tank pressure provides more usable air per tank re-charge
Six-gallon tank provides excellent reserve capacity
$160
What's the difference between scfm and CFM?
Should I go with a larger tank or are the hot dog style good enough for inflating tires and blowing out seams?
Thanks!!!
