Aero flex line trimmer replacement.
PA DETAILER
DETAILED TODAY?
Aero-Flex Line Blade Trimming Systems
Appears to be a good idea to me. Better than always buying replacement spools or line. Did some research and the product appears to be good. Had the PLASTIC blade replacement head years ago, and that was junk. As soon as you got close to rocks or a hard object, blades broke.
Guess I`ve just been lucky, the bump-feed head I use is still working fine after gee...twenty-some years now (got an industrial size spool of line ages ago, still using it up, maybe have another five years or so to go).
I`ve used the plastic blade head for heavier trimming, mine didn`t break when I hit rocks..maybe the Stihl blades were worth the $ after all.
Wonder how long those Aero-Flex lines last...and how easy/quick it is to replace them. For some reason I just knee-jerk-suspect that it`s not that swell an option, hope I`m wrong if you try it.
