Changeling
1999 Toyota Tacoma TRD, Black (never detailed). Using PC 7424.
These are the "Polishes" I am going to use, to prep the paint (Black) on my truck.
3M 05933 Rubbing Compound and 05937 Machine Glaze
The 05933 will be used to go around the truck and correct the bad scratches/areas.
The 05937 will be used over the entire truck to get rid of the swirls/oxidation and blend the areas that were hit with the coarser 05933.
Question: I am pretty sure that I should use the White or polishing pad with the machine Glaze.
However, I am not sure about the problem area pad choice with the 05933.
When I am working the bad areas, I believe it should be an Orange/mild cutting pad, but not absolutely sure, and would appreciate a little guidance.
The above will be followed by Klasse AIO and again a white polishing pad, or should it be a milder pad like gray?
The Klasse SG I intend to "whisper on" the whole truck, to quote a lot of you guys, then remove later by MF towel or by PC with a MF bonnet, if I decide to even use it.
From there on I think I have a handle on everything you guys have beat into my Grey matter, but then again?
All of you have been extremely helpful in assuring I understand things and I want you to know I really do appreciate it!!
Changeling
PS. If you see a hole in the above plan as laid out don't hesitate to contradict my intentions.
Changeling
