I also have one and it's super easy for one person. I do it by pylling out each corner, working my way around until I can lock the pins. Then all I do is lift one side and extend the legs, then the other. I can set it up in less than five minutes.
Takedown is even easier, I retract the legs, then unlock the pins and just lift a corner and walk it into itself.
Once you do it a couple of times you'll be an expert!
