Some people are confusing distilled water with de-ionized water.
Distilled water is water that is turned into steam (or vapor) and then condensed back into liquid form, but without most of (but not all) of the minerals, chemicals, and contaminants that may have been found in the original water source. Multiple distillations will produce an almost pure, mineral-free water.
Deionized water is deeply demineralized, ultrapure water used in microelectronics, printed circuit boards, instrument manufacture, pharmacy, washing liquids, etc. In order to obtain the high quality, pure de-ionized water a multi-stage water purification process can be used. After pre-cleaning, the water is supplied to the reverse osmosis membrane, and then the water is filtered through a special deionization medium, which removes the rest of the ions in the water. The purity of deionized water can exceed the purity of distilled water. I think that`s the type of water a CR-Spotless water filter system produces, although not to clean-room or laboratory specifications, but mineral-free enough for car washing, so that when used a rinsing solution, it will not leave mineral-spots if left to dry (evaporate) on its own without the aid or use of some type of drying medium (air blow-off or chamois or microfiber waffle-weave drying towel). Those of you who have to use hard water know the pain this can cause when washing a car with the traditional 2-bucket method. It`s also the reason so many of you have changed over to rinse-less washes like Optimum Polymer Technologies No-Rinse (or ONR, as it`s know here) and use distilled or deionized water for this expressed reason.
I would think that the water filtration system to produce Zero Water is similar to a Brita filter to produce clean, healthy tap drinking water. One other thing that a Brita filter does is to filter out cryptosporidium (amoeba) that can cause serious health issues. This is especially true in areas that have ground water contamination from farm-waste (manure) run-off. (like the Dairy State of Wisconsin, with its fractured karst limestone bedrock). I have no idea how much heavy metals (lead, mercury, arsenic, radium) are eliminated because they do not use a reverse-osmosis process or distillation process, but it must be enough to meet current EPA drinking water guidelines and standards.
