Zaino streaking
micnic
The last 2 times that I have applied zaino, I have noticed some streaking. I didn't notice this until after the 3rd or 4th coats. Is there something else I should do to apply additional coats such as another coat of z-1?
Streaking, maybe too thick as stated.
How long are you waiting before removing the Z ? I've had a few streaks before on spots that weren't ready for removal.
Welcome to Autopia :wavey
I am pretty sure that I applied the approximately the same amount each time. The temp has been around 50 degrees the last couple of times that I applied it.
Are you using Z1 or ZFX?
How many coats per day?
How much product per coat do you feel you have applied?
Humidity and temperature conditions?
I have found that Zaino streaks if:
1. You let the product setup properly in high humid or low temperature conditions
2. You apply the product too thick
3. You apply to many coats in one day (I usually only do 2) using ZFX. If you going the Z1 every 10 coats, then you can only apply 1 coat per day.
I agree with the "too thick" analysis. That seems to be most encountered.
It also may not be dry if you aren't using ZFX. Use the "touch test". If you touch the polished area, it should come off clean without a "greasy smudge".
