Zaino Questions
rednckdetailr
Hi Everyone,
I've been reading autopia.org for quite some time,and i have alot of products,as well as a porter cable 7424 & the pad kit that i ordered from autogeek a while ago. I just ordered Zaino & the full line of collinite products to add to my collection. I was wondering how everyone uses their zaino,how much they mix with the zfx fusion additive. I'm a total newb to Zaino,but i've read so much good things about it from here i just had to try it.
I ordered the Zaino ultimate protection show car kit that has the zfx flash cure accelerator additive,z-2 pro,z-5 show car polish,z-6 gloss enhancer spray,z-7 show car wash,z-9 leather soft spray cleaner,z-10 leather in a bottle,z-16 perfect tire gloss and the z-18 claybar
I also ordered z-12 clear-view glass polish & z-14 plastic magic cleaner & polish as well as the Z-PC Fusion Dual Action Paint Cleaner Swirl Remover.
I apologize for being long winded,but i was wondering if i selected the appropriate kit to startoff with. It's already on the way to me :woohoo: and i'm already addicted to detailing.
I'd appreciate some newbie Zaino pointers on application and mixing,etc.
Thanks,
Peter
Great choice.
You do not need ZFX with ZPC
What color car? what shape is the paint in? Also size of car will determine how much Z5 & Z2 pro to mix up. I have a Mazda6speed and for two coats of either Z5 or Z2 pro , I fill the bottle a little less than 1/2 with 2-3 drops and I am good to go including rims.
In general:
You should clay 1st, use ZPC, then Z5 ( coats up to you ) then Z2pro ( again # of coats up to you)
use Z6 ( I use Z8 ) between coats and after.
I would definately get Z8
You got a very good kit.
The most important pointer I could give is emphasize your prep with the Z-PC Fusion.
Polish that baby!!!. ;)
Dogma I must respectfully differ.
You do need ZFX to mix with your Z5 and Z2-PRO for the initial coat even when using Z-PC Fusion as your prep polish. Subsequent layering down the road can be applied without ZFX but I highly suggest using it for almost all applications.
As Dogma stated we need to know the size and color of your vehicle. Many times 1 oz of Z sealants (Z5 or Z2PRO) is waaaay too must for even 3 coats on my C5 and normally enough for 2-3 coats on my Escalade. Let us know what you got and we can suggest how much sealant to mix up.
I also suggest getting Z8 (QD/Spray Sealant) at some point to maximize your appearance and almost inifinitely prolong your protection.
Also the best source of information is Sal Zaino himself. Call him or any of his guys and they will point you in the right direction. :hifive:
Oh yeah, Welcome to Autopia!!! :woot:
The vehicle i am going to do first has already been polished with 3m perfect-it rubbing compound and a orange cutting pad from autogeek.net and it currently has nxt on it as the lsp,the vehicle is a 93 Volvo 940 Turbo station wagon. The roof needs to be spot-clayed,but i have already claybarred the whole vehicle and done proper autopian polishing,but the roof has some bird s#$t that got on it,that didn't washoff the last wash. Basically i think i need to apply zfx fusion with z-2 pro polish mix x2 coats because there is no swirling in the paint whatsoever and it is 95% defect free.
Please advise further,thank you all for the replies,and thank you for the warm welcome to autopia.org :bounce
Even though the surface will be defect-free I personally would use Z5/ZFX for at least one coat. Z5 has slight different optical enhancers in its formulation and from my experience, not only hide/fill very minimum surfaces marring but also adds richness to the final appearance after subsequent of coats of Z2PRO.
1/4 oz of Z5 with 2 drops of ZFX should be plenty for 1 very thinly applied coat on a Volvo wagon
1/2 oz of Z2PRO with 3 drops of ZFX will be plenty for 2 coats.
Each layer should be applied very thin. Slightly prime applicator with Z6. This will aid in applying a thin and even coat. After applying the sealant should almost invisible, especially of light colored vehicles.
Allow to completely dry. I usually allow about 30 minutes.
Buffing will be a breeze.
QD with Z6 is optional between coats but is highly suggested.
Sounds like the hard part is done (PREP).
Now the fun begins!!! :clap:
dogma said:
Great choice.
In general:
Guess I didn't explain it right in my haste. Yes you need ZFX with Z5 & Z2pro, no you do not need ZFX with ZPC fusion. As I tried to state , I fill the bottle almost 1/2 way with either Z5 or Z2 pro then add 2-3 drops of ZFX. This seems to work well for me with minimal waste ,it does 2 coats and rims.
Hi again to everyone who replied, i forgot to mention the color, it is a really pretty Gray metallic color,which the paint was super hard and it took my porter cable to it's limit (i had to use 3m perfect it rubbing compound on a orange pad at speed 6 to remove the paint defects with light pressure.
My other questions i have thought of are, it is outside 24/7 under trees, do i really want to use my precious Zaino :soscared: that cost me a pretty penny, or should i use Collinite cause i also ordered the full line of Collinite waxes.
I ordered #845 Insulator Wax,Liquid Sapphire Auto Wax,Fleettwax Heavy Duty Paste Wax,Paste Sapphire Auto Wax,Fleetwax Heavy Duty Cleaner Wax (Pint) from
http://www.nealsharbor.com because i see some not so frequent customers and i thought it would be a good idea to keep a simple one-step cleaner/wax on hand for these people.
I also have Blitz One Grand Carnauba Wax that i just ordered and recieved to use on properly prepared finishes. I have alot of other non-otc products too that i have searched out,such as the beloved #16 Paste Wax by meguiars, i have 6 cans of it! :woohoo:
Anyway, i want to thank anyone who replied for the warm welcome to autopia,and i think this is a wonderful addiction i am going to dig myself a deeper hole into.
Btw, i'm already crazy enough to wash & wax the lawnmower every 2 weeks!
Why not. Any vehicle the is exposed to the elements 24/7 will need more frequent TLC.
From reports here at Autopia, Collinite is very durable. From personal experience Zaino is unbeatable for my frequently exposed vehicle (Escalade).
It's a win win decision
Zaino will look great on grey metallic. Go to DetailKing's garage. He has a similiar colored BMW with Zaino protection. :drool:
[quote name='blkZ28Conv'].
QUOTE]
How do you measure such small amounts? I typically do 1 oz (half of the supplied 2oz containers) with four drops of ZFX. Doing a C4 and C6 this was enough for three coats, windows, wheels, and exhaust and I *still* had to waste some of the Z.
On my wife's mid-size SUV the same amount was enough for five coats including all of the above, again I had throw some away.
I wish Z2PRO could be used without the ZFX. :(
Look for a 35 mL oral syringe with a small tip. There are smaller syringes (usually 10 mL); I haven't found them useful. Also, my vet has two types of 35 mL syringes, one with a small tip, the other is fairly large. Get the one with the small tip for better control, less chance of spillage, etc.
Tort
QUOTE]
5 or 10cc Syringes (3-4cc for 2 coats on C5 and about 7cc for 2 coats on the SUV)
After the initial application of Z5 or Z2PRO with ZFX or Z1, Z2PRO can be used alone for single coat applications. :bigups
__________________
2000 WS6 TA NBM
I guess I forgot to mention why I prefer the larger (35 mL) syringes . . .
I usually only mix up about 1/2 ounce of or so of Z with ZFX at a time, and I do the mixing in the syringe. The extra volume in the syringe provides some head space so that shaking to mix works a little better. Once mixed, I remove the excess air before dispensing.
BTW, if anyone is thinking about giving the "Zyringe" a try, here's another tip that should make filling/mixing a little simpler: http://autopia.org/forum/showthread.php?p=197419#post197419
Tort
I did a 1994 Honda Accord Lx Coupe the other day with the zaino
My process was:
Dawn Wash
Dry With Absorber
Z-18 Claybar With Mothers Showtime as lube
Z-2 Pro 1/4 Oz with 4 drops zfx additive x2
Z-2 Pro On windshield inside x1 coat & x1 outside coat
Z-16 Perfect Tire Gloss on tires x 2 coats 20 mins apart
Greased Lightning Auto & Shop Formula Degreaser on wheelcovers & tires
Stoners Ig On Inside & Outside Glass
Vaccum Inside & Clean Trim,Dash,Etc with greased lightning
No Interior Dressing
Sorry no pics,camera batts were dead, lots of metallic flake pop from the gold paint,very good reflection under 1200w halogen worklight on stand, interior carpeting needs shampooing but it was a freebie detail for my best friend, and he is flexible so i will get some after pics next time he is over when i do the rest of the interior,etc.
P.S: Cannot afford expensive microfiber towels right now, i have found some fairly plus mf's at wal-mart that i am going to buy 3 or 4 8 packs of for removing the zaino, i know it's not autopian and i pardon the sin, when i have more money i will buy better mf towels, i promise :sadwavey:
