zaino question
On the Zaino description it says its not intended for everyday use, so i am really sure it does. It is not powerfull enough to remove enough clear coat to be visible. As long as you dont leave the running on the same spot for an hour you should be okay.
it's totally safe for repeat use-a couple times a year and you'll be ok. If you use it weekly then you will cause a problem.
ZPC is like any other corrective abrasive...each use diminishes a very slight amount of clear in order to correct surface problems. That is the nature of abrasives though, no way around it. That said, it is safe for the finish and would take major misuse to ruin a finish.
Z-PC like all polishes must be respected for what they do - polish. Polish requires some material removal to level and refine the surface.
Z-PC is designed to be used at most several times a year and it abrasiveness can be adjusted from being just a paint cleanser to a mild polish depending how one works the product, pad selection (hand, PC or rotary), pressure applied and time spent on an area.
When used properly Z-PC is a very safe product for clearcoated finishes.
