ChicagoRay
wash them or get rid of them???
I used them to apply some wax once
Intel486 said:I use them, then soak them overnight in a bucket which is full of Dawn and when I fill it up I use hot water. Then I just run under clean water, squeeze out, and repeat a whole bunch of times. Then air dry.
trkmedic69 said:
thanks - about how many times would you do this before replacing?
carguy said:I throw them in the washing machine with my other towels and wipes. don't put them in the dryer. OK to re-use - for safety's sake I mark on mine with a laundy pen what I used. I never re-use a pad marked for "product x" with anything less aggresive than that product.
I wash on hot water cycle and run the rinse twice. I air dry and everything is fine. I save lots of money here and there by washing these.
paul e said:For you guys with the machine washing of the foam pads, does the machine ever do damage to either the foam, or, to the velcro backing? Im afraid the backing will either get ragged, or the water will soak the backing which will then disintegrate, and lose its ability to hold the pad well on the buffer.
