What combination?
BMcN
OK I am in the UK and am going to order a PC buffer off this site.
I was mainly wondering what things I need to order with it. I was going to get the Sonus pads then what else would I need?
The cars I am going to use it on are covered in swirls and slight scratches.
So could you reccomend me somethings to get? Maybe a swirl remover, scratch remover, and a good polish (one to give a deep shine and good protection, don't mind if its machine or hand applied).
Also, while typing this I just thought of something. Import Duty! Would the Autopia guys stick a gift label on my PC buffer if I was to get it from here?
Depending on the severity of the swirls a lot of people like the 1Z products. I used 1Z PP followed by MP recently to clean up some light swirling and it did a very nice job.
Others have much more experience with different products and will be able to provide a lot of valuable advice but until then you might check out the learn section and see what you can find by doing a search also.
Good luck!!!!
Just looked into Duty and it turns out it has to be under £39 (I think) to get away with the gift idea.
Might be able to get a 7336 here in the UK but then where should I get all the diffrent pads from? Would have liked that Sonax set of pads. What pads am I best getting? And do I need a flexi pad thing to mound my cleaning ones on?
Where can you buy a PC in the UK? Once you have the PC and backing plate, the pads are a personal choice. If you like the Sonus then you need to order from Autopia. You can buy the Meguairs pads in the UK.
