True paint cleaners/polishes that don't leave anything behind.
imported_jgv
P21S PWCL, Pinnacles CL, 4Star UPC, Klasse AIO, Megs #9, 3M SMR, etc. All these are mild polishes/paint cleaners that will leave something on the surface after removal of product. You can see it thru slickness, shine, etc.
Which are those true cleaners that only clean/polish?
And presumably 3M's PI-III MG (pn 05937). It's supposed to be "filler free". Like the Menzerna stuff, it's really just a polish, but it'll "clean" through abrasion.
BTW, I dunno if I'd assume residual product based on shine, slickness, etc. The smoother you get the paint, the more I'd expect to have those characteristics anyhow.
BW,
The Menzernas dry out very quickly, and can be a sonufagun to remove when dry. I've always thought IPA was recommended for that reason. My experience has been that if you pull out the removal cloth at the right time, IPA is unnecessary. I haven't used it with the Menzernas for quite some time.
Tom
The M-Twins are water based and from my experience, don't contain any fillers. I've used the alcohol/water simply to remove the stuff that won't come off. After final polish, the paint squeaks like nothing else I've used. Also, another IP/h2o pass shows no difference in it- hence no fillers removed.
I had the Menzernas in mind also. I'll just add some more:
Farecla G10
Presta Glaze 3000
Poorboys Pro Polish
Meguiars Medallion Paint Cleaner
I believe that Steve at Poorboy designed his products, like the SSR's and the polish, to be body shop safe. That means no fillers etc.
