Time to step up to wool?
Don GM
I've polished my Jeep many times with an orange pad and OC with heavy pressure, the swirls still appear back after the top coat wax fillers wear out. Should I use a wool pad on my rotary, then bring that down with the orange pad and some OP on the PC? The clear is rock hard!
GMblack- I'm using the PC now, sorry I didn't put that in.
Tdekany- I don't have a yellow pad on hand, that's why I'm contemplating the wool. Of course I can order one, but I'm afraid it won't do much better than the orange. Is there a big difference between the orange and yellow?
If you have a local body shop supply, try picking up Presta's Ultra Cutting Creme Light and their velcro-backed green wool (the shop might have to order the pad). If that doesn't work, step up to their yellow wool and follow with the green.
