I've been using this stuff for about a month now and I have to say I'm very impressed. It's the easiest to use product that I've ever tried and it leaves a very nice looking and smooth finish.
When I use it as a polish it removes light scratches and oxidation and then preps the paint for Stoner Sealant or a wax. On a scale from 1-10 I would give it a 3 for aggressiveness because it does not have any abrasivesEDIT: Just found out it DOES have very light abrasives. . I work it just like I do DACP but it doesn't break down like DACP. It starts off very thin and when your done you can barely even tell that there is anything left on the paint. I polish the entire car making 3-5 passes on each section and then buff the car at the end. I find it's just as easy as removing dust that DACP leaves behind after I polish with that.
The finish it leaves isn't very dark but it is like the car is wrapped in saran wrap as sealant is usually described. For this reason I only use it on light colored cars because I prefer the deeper finish that DACP leaves on black. It does leave the surface very slick and when I apply the Stoner Pure Sealant by hand it glides on like butter and removes like a light dust. I have tried to apply the pure sealant on a car that wasn't prepped and it is difficult to apply thin.
When I use it as a one step cleaner wax I apply it very thinly with the PC over the entire car and then remove with a MF. It doesn't leave the car looking as nice as when you use it as a polish but it is a good quick wax.
The price is very good for a cleaner sealant such as AIO at $30/gallon shipped and cheaper if you buy in larger quantities. The ease of use and slickness are both excellent, I couldn't imagine a product being easier to use. It is definatly best used on light colored metalics as it really brings out the sparkle.
