Stained Exhaust Tip
spencer785
hi there okay my exhaust tip is a single wall stainless steel and i have tried steel wool 0000 with windex and optium metal polish and eagle one nano wheel polish. And nothing works its like its stained with these spots everywhere. Anything you guys can suggest.
any way possible you could post a picture of it up so we can see what we are working with here?
At that point someone can guide you in the proper direction
Almost looks like failing chrome...
I had a header pipe that did that once... looked exactly the same. Actually failed due to heat... but thats odd being that far back on an exhaust system...
That almosty looks like a etching from a chemical as its random spots. I may not be correct, but Im almost positive that it looks like a acid stain. Ill bet someone used a hydrofloric on that tip. I have done it before in early days when Hydrofloric was real popular. The good thing is its only a tip a new one can be purchased and welded fairly cheap.
