SSR 2.5 / 1.0 combo or Optimum Compound
JoshRed
Hi Guys,
I would just like to know which one will you get if you are given 2 choices between two products?
Poorboy's SSR 2.5 / 1 combo or Optimum Compound (not the Hyper)? (only these 2 products are available locally)
I'll be buying soon one or the other and I would like to know what will be the autopian consencus before buying?
car is red with moderate swirl and some heavy on some parts, clear coat (sikken paint). Will be using PC.
Thanks
Do you mean 2 choices between three products?
I'm not sure I really like your options...All I know is it will take you a long while to remove the marks left by 2.5 usiing SSR 1. Going from 2.5 to 2 would be better if this is available to you. If you really had a choice between these two lines, I'd probably go with SSR 2.5 to OP.
