OneQuickGT1 said:Very interested in trying the new line. On harder clears, does Uno finish down well enough (light color), or is the final polish really required? Also, what is the cure time if I wanted to apply Poxy over Speed?
Thanks so much!
Ben@Autopia said:On hard clears, that is where Uno really shines. No final polish is needed. It will finish down nicely if you use a mild pad.
DitchTehFish said:Then again, if you're using a mild pad on *hard paint*, you're not gonna get much correction.
Ben@Autopia said:Yes, you will need a more aggressive pad initially.
DitchTehFish said:Ahh, you mean following with a softer pad. Gotcha.
