Premiere Auto
Just scored for FREE a LIKE NEW small extractor!
I was working a jobsite today where they were remodeling a bunch of storage rooms....they had a pile of commercial cleaning stuff they were throwing out...most of it was old junk..then I saw the little machine sitting their...ask the guys if I could dumpster dive and they said GO FOR IT!!!! SO I DID!!
Here are some specs off the companies website:
Anser™ Spotter Extractor
Spot clean a variety of soft surfaces with the portable Anser™ Spotter Extractor
Key reliability and performance features
Unit is like brand new..may have only been used once....got it home...wiped it down and fired it up...works flawlessly!!!
I'm going back tomorrow to see what else I can find!
Here is a picture of the unit (mfg. photo)
- Perfect for small stains and soil concentrations
- Easy to transport at only 18 lb / 8.2 kg
- Recovers water easily with the 1.12 hp / .84 kW vacuum motor
- 2 gal / 8 L solution tank; 1.5 gal / 5.7 L recovery tank
- 1.12 hp / 0.84 kW, 2-stage vacuum motor
- 120-volt solution pump; 30 psi pump pressure
- 8 ft / 2.4 m vacuum and solution hoses
- Durable, corrosion-proof polyethylene construction
- 25 ft / 8 m power cord
- 4 in / 102 mm clear hand tool
- 8 ft / 2.4 m vacuum hose
- 8 ft / 2.4 m solution hose
