Yep, that makes a lot of sense, but i'm witting back on this only to make sure i got it right(i err on caution side so...)
For instance today, i was doing a toyota tercel ; i taped everything rubber or plastic round that car + on door panel i taped the body line that runs between the molding and top of door, as the clearance is about 6 inches and my pad 8 inches(3m polishing pad). Doing the hood and trunk i popped them open so it was easier to run off the edges. When doing fenders i get very tense so to speak, althought i was using the 5937 from 3m. So on fenders and top rear sides(these are much like fenders, as they have round edges and places where pad could burn paint easily) i tilted the buffer and ran it on them but very fast, moving with the bend(or round edge).......is this ok ?
Doing the hood, where do you place yourself ? in front of it, or on the side ? As to me i placed in fron to do the middle part and on the sides to do the sides(left and right) of the hood. The lower front part of the hood goes round as well, so i guess you move with it, tiltingthe pad so the middle doesnt sit on top of the curve, is this correct ? Doing them i never insist, i make about 2-3 quick passes, no more.
Please bear with me Guitarman, as i really need help on this and insist on doing good quality jobs. I literally freak on those rounded parts mentioned above, like fenders, and top rear sides, there s no flat surface there at all, so what i do is move with the curves.........i only use say half the pad there, so the middle part doesnt abrade the ridge of the curve.
Also, that toyota tercel has angled/curved bottom door panels, what i did was move up and down alongside that part.......i mean i ran the buffer on an up and down motion so as to flow with the curves, and this going left to right till it was completely done.........is this correct ? I also tried to figure out a way to do that part otherwise but i didnt find any better way then moving with the curves........sorry if i sound a bit erratic, im so beat
Now on hood ridges ; the ridge has an upper part(a peak) and a lower part(a velley so to speak)...i just position my pad so i dont run on the ridge.........i do the upper part, then the lower part, but never am i buffing on the ridged curve.
What is the outer edge of the pad(i know it sound stupid to ask but ..) let s say im facing the hood, doing a side of it, moving left to right, then the outter edge would be the part that would hit or slap the edge of the fender panel if i didnt tilt it,right ?
Gee buddy, if i can get this cleared upl, ill be in heaven :xyxthumbs
By the way, as i said im a bit sorry to ask so much, but i have trust in you and appreciate your help a WHOLE lot.
Regards
