Reload Streaking
topsyt
I used Reload on my dark red/maroon truck as a drying agent, and now it has really bad streaking. I've read the many threads on reload, but didn't see any suggestions on how to correct it? I probably won't use reload any longer on this truck, but would like to remove the streaking without removing the coating.
Thanks
At the risk of being told that I have an "axe to grind"
Good luck. The more remedies I tried, the worse it got. Let it wear of naturally is my advice
Two words: User Error.
Wait, one more word: ^Lolz
Sorry, not your fault OP. Many have reported this issue with this product. You may have to polish it off.
do you have any paint cleaner such as JW Prime ? that will take care of the streaks, without removing your coating. if you do not have than many streaks you can do it by hand. I used to get streaks with reload I used too much product or used it in the sun.
I'll do a few wash cycles (over the next several weeks) and see how much it wears off. Definitely don't want to start over. Thanks
