quick connectors dont understand
blownvert
Im ready to buy my gilmour foamaster, probably get the brass one. Now about all these shut off valves and quick connectors. Seems like AG sells them and there not cheap. This is what I want to do. I want to have a shut off valve on the end of the hose, where you connect and disconnect your foam gun, spray nozzle. I also want that easy connect and disconnect from the foam gun and spray nozzle (fire hose nozzle). From my hose end where I have to hook it up to the water supply, it leaks when i twist it on and turn water on. I have tightened it and it still sprays out everywhere somewhat. So I guess I want a quick connect on that end also to stop leak. Do people just put quick connect on the other side where spray nozzle is? So please send me in right direction, I have searched and looked. Seems like dramm #300 looks good and gilmour quick disconnects from lowes. So again what do i need?
Just go to lowes or home depot and go to their gardening area. Plenty of shutoffs and quick disconnects to be had.
I know they have that stuff there, even sears have that. I dont completely understand how many I need, since 1 comes with the foam gun. :)
Is the entire coupling coming with the foam gun? If so, you'll probably only need one male fitting for your regular hoze nozzle. I also added a shut-off valve to make the transition between devices easier.
blownvert- To save me some typing :o please see the other thread we have going about the foamguns; I explained how I set mine up and I think you'd like that approach. See if this link works: http://www.autopia.org/forum/detailing-product-discussion/106734-gilmour-foamaster-2.html
(IF you can't find it I'll rehash it next time I'm online.)
For the leakage at the hose/spigot connection, you probably just need a new washer in the end of the hose where it connects to the spigot, or else your spigot's threads are messed up (they sell a cheap thread restorer for hose-size connections). Adding a quick disconnect without fixing the proglem will just result in the leakage happening there.
how many you NEED=0
but to make like a little easier
grab a Female quick connent and shotoff valve for the end of your hose
and a male quick connect for each of you hose items
foam gun, reg firemans, power washer, ect.......
Oh ok, so I dont need a quick connect for the end where i hook up the hose to the water you think? So basically 1 female quick connect, 1 shutoff valve and 2 male quick connects. So basically now which are the best, gilmour? Dramm is expensive and seems only online.
Unless you switch hoses or move them around - in which case it's nice to have one on that end - nothing on the supply line.
I've only used Gilmour, but I've been happy thus far.
I only have 1 hose. Im just talking about since im doing quick connect on one side with the foam gun, nozzle, why not do it on other side hooking it up to the water supply? I dont know.
i just did what your talking about last week to my hose , gilmour and water nozzle
i got all my stuff at Walmart.
i think i paid no more than $5 for this shut off valve (thats a female end of the quick connect on the end of it)
the brass quick connect sets were $5 a piece
i also had to fix my hose since it was leaking like crazy at the end where the hoze connect. i bought a repair kit which consisted of a new end and a clamp at Walmart also for a few dollars. i bought 3 QC sets but i used 2 female ends and all 3 male ends. i just connected the shut off valve to the hose so i could leave it on there instead of pulling it off and on so when i pull the lawn mower around to spray it off i can use the shut off switch to control the water flow instead having to go grab a nozzle and have to put it back when im done. all this stuff was on the same shelf in the lawn center. im leak free except for a drip that comes out of the on/off handle on the spigot, from the spigot out to the end..nada
sas7 1: I just went to walmart looking at the pieces for a hour lol, the brand they only had was i think sun lite. They dont have gilmour. I was in the gardening section. Does it matter what brand, they are brass. The shutoff valve is the same one I was looking at that you have. Ya i price checked it was $4.92. The brass quick connect set was $4. And 1 quick connector was $2. I didnt buy anything because im buying that fire hose nozzle from sears. I wanna do what they have. I checked on there website, but I didnt like the shutoff valve they have, but they had gilmour stuff. Also my hose leaks also at the spigot, I got the sears black durable hose. So I would buy a whole new end hose connector with that metal ring to seal it.
go to sears and you can get the craftsman quick disconnects or lowes as they should have the gilmours. IIRC, they both have a lifetime warranty...
sas71 said:
im not sure the brand name of the ones i have but they work like they should
oh i thought you said you got gilmour. you prob got the brand i saw, didnt seem like anything was wrong with it.
the pic i got from autogeek.com . i was too lazy to unscrew a male end of one of the ones i bought and take a pic of the male/female ends because my cams batteries were low. i snapped the photos quick :buffing:
yea, walmart has sunlight.
Lowes has gilmour in the plastic and metal quik disco's. Ive been using the plastic ones myself to save a few $$ and they are working out great.
Haha, looks like you have the same shut off on your house as we have sas71. That thing was put on the house back in the 70's and its still going strong! In the past couple years its started leaking some though..
you have any water restriction in the sunlight one you got from walmart? It looked like a little hole, but i havent seen others so i dont know. i just heard people talking about water restriction.
That water pressure at my house is already very poor so I cannot really notice a difference. Im sure if you had great water pressure and wanted alot of water flow you may notice a decrease in flow but probably wont notice a drop in pressure given youre using a sprayer that doesnt use alot of water. :)
