Product combo ?
RB88
So I got some Klasse AIO and Klasse glaze along with Natty's red for Christmas. Obviously the Klasse products will work together, but how about topping with the Natty's red? Application(hand) tips certainly welcome... Oh, I have several microfiber applicators is this ok, or should i use foam ones. Thanks for the help.
The key with Klasse is to use sparingly (especially the KSG). They work well by hand. I usually spritz an applicator (either foam or MF with a little QD prior to application). Definitely allow Klasse to cure(12 hours) and then application of Natty's red will not be a problem. BTW, Natty's is also super easy to apply and remove.
KSG works best after 3+ coats
IMO I would use the Klasse twins for the winter
then the nattys in the summer
there are a lot of threads with tips for applying KSG
but the most important thing is to apply it thin.....thin as in you can't see it going on but know it's there thin
Always allow SG to cure for 12hrs, before topping with anything else.
There are many favourite methods of applying SG without any grieve.
This is mine:
1. After buffing off AIO, spritz a 50/50 mixture of SG/water and wipe off.
I believe, this "primes" the surface to accept SG with no problems.
2. Put a small drop of SG onto a MF pad dampened slightly with QD.
Put on ultra-thin, almost unnoticeble coat onto the panel. Wait 30min. Buff. Or you can buff immediately ala WOWO method (wipe on wipe off).
I've had no problems at all using SG this way.
Yeah, KAIO followed by a few layers of SG and topped by a beauty was like Natty's is what Mayor DavidB used to call "The Perfect Shine" (of course, that was using P21S). And to echo the other posters on the SG...thin, thin, thin. Stay thin with the AIO also, that can build up some difficult-to-remove residue in panel edges, etc.
