porter cable speeds...
gtmustang00
what speeds do you use for
poorboys ssr 2.5
poorboys ssr 1
Poorboys exp sealant
Clearkote red moose machine glaze
Clearkote carnuba moose wax
Optimum Poly seal
Dark Colors.......................Light colors.....Metallics
ssr 2.5...............................ssr 2.5...........ssr 2.5
ssr 1..................................ssr 1..............ssr 1
red moose machine glaze.....????.............Ex p sealant
carnuba moose wax.............?????
Also, what products do i use on the light colors for the final products? I have yellow, orange, white and blue pads.
General rule for speeds:
Polishes and compounds: spread at 3, work at 5-6 until dry. Start with the least aggressive combo and work your way up until correction is achieved
Glazes, sealants and waxes: spread at 3 and do not work them in, since those do not have any kind of cleaners or abrasives, just make sure to spread evenly
Speaking of porter cable speeds, I just used mine for the first time and I put it on 3 to spread and then 6 to cut since my wife's '98 mustang was in pretty bad shape. Is it normal for the Porter Cable to vibrate like a bat out of hell on 5-6? The vibration was so bad that my right hand holding the bar grip has soar muscles like I just worked them out.
yup...the vibrations are fairly significant. it's worse if the pads are not perfectly centered (speed 6 especially). the first time i used my PC, my hands were numb/tingling for quite a while after. you get used to it after a few uses.
ttt........ for light colors what do i use for the final coats? the sealant by itself? the wax by itself? the glaze then the wax?
Here's UPGP
