PC pads cleaning
princetonymc
After applying polish with the pad, how do you clean it so it won't be to hard for the next use or do most people throw it away and use a new pad.
DO a quick search, there are tons of threads on this...I use Danase pad cleaner followed with a soak in dawn.
holy crap, throw it away? That would get HELLA expensive. I put mine in a bucket with a small amount of detergent and let them soak, then I rinse them in a sink.
I wash them in the washing machine with warm water and laundry detergent. Have not had an instance where they did not come out prefectly clean.
I would not recommend hot water, this seems to contribute to velcro backing seperation.
Throw them in a bucket and use some Dawn, like you would be washing out your socks with about the same concentration of water vs Dawn. In fact, wash them just like you would do your dirty socks, rinse very well and let sun dry. No fuss no muss. This isn't rocket science just use some common sense and you will do fine.
Changeling
I just dump it in my leftover car shampoo solution or use Woolite. I leave it there for about 30 minutes, then I go and try to squeeze out as much product as possible. Then I leave it for a day or so. Seems to do a fine job at getting everything out of the pads.
I soak them in warm/hot water and Snappy Clean powder or just car wash solution, for about 15-20 mins... then I take them out, wring them a little bit, spray with APC+, let them sit for a few mins, rinse out.. they come out great every time
DO NOT throw them away... many pads today can last years... I still have an old autogeek/wolfgang pad from 1.5 years ago... looks brand new
kleraudio said:
wow, jackson you wash then in the washing machine? no problems?
i have to try that!
do you air dry?
Jim
Yes, just let them air dry.
Only problems that I have has is washing pads in hot water. I have several pads that I have wash probably 20 or 30 times (in warm water) and they are still holding up good.
I've put mine in the washing machine for years including cyclo pads. Haven't had one go south yet and they come out pristine even after single stage black.
Depends what I used on the pads, but I have Dawn power disolver (which actually impressed me a little bit), Dawn ultra or a degreaser...I spray a little product on and work it in then rinse with hot water and repeat until everything breaks down.
WHat do you do to clean the pads mid-panel with a PC? In other words, do you spur the pad, brush it out, or something else to extend the working time with the pad until you have to throw it in a bucket and grab a fresh pad?
There's alot of different way to wash pads. I used APC,XMT,wash machine, soap,etc. All works to be honest.
All of the methods so far will work great. The only thing I could possibly add is that using HOT water will make a big difference in getting the unused product out of the pad.
Also, using some type of pad rejuvenator (like the one listed above, plus others) every so often will keep them nice and soft.
