imported_sal3291
My PC 7424 has 2 weights with it. One says use with 5" Pads the other says 6"pads. If I am using 5.5" pads and 4" pads do I just use the weight that says use with 5" pads?
Yes, but it wont make any difference. Try it, you wont notice any difference between the two counter weights.sal329 said:My PC 7424 has 2 weights with it. One says use with 5" Pads the other says 6"pads. If I am using 5.5" pads and 4" pads do I just use the weight that says use with 5" pads?
SuperBee364 said:Either way your hands are still gonna go numb from the vibration.
charlesaferg said:Never had that problem, and I've been running mine until the darn plastic cover is shaking itself apart. I think my hands are holding it together, but it still performs like a champ. Not very great on the durability scale, but it sure has worked well for me.
I still use all 3 machines...
KnuckleBuckett said:The vibration was the #1 reason I sought out a better solution. Several other reasons as well, but the vibration was tops.
Flex rocks thus far. Easy to use pretty safe and cuts so much better.
