PB's Bug Squash
Intercooled
I was poking around the PB web site and noticed a new product called Bug squash for bugs, sap, road tar and grime. I wasn't sure if it was a spray on application like a Qd or an additive to the soap bucket.
Anyone use it or know anything about it?
It's a pretty good product IMO.
I haven't tested it to "equivalents" yet though.
I have used it on all "about to be detailed" vehicles. Hose down the car and spray on generously (cut 1:1), then use a "bug scrubber pad" to scrub the crap away. The pad feels very abrasive but doesn't really marr the surface. It helps a lot and will really preserve your clay bar (this process)
All in all, the product works pretty well, but like I said, still need to test it against equivalents.
Where do you get the bug scrubber pad?
Is the Bug Squash a liquid or a gel? Does it strip wax away? I have a mixture of P21S soap and water in a spray bottle, with a touch of QD for removing bugs...which would be a better solution for daily bug removal?
I too saw this product, but know very little about it.
~Darren
I tried this at the Pb's Detail Day, it was a thin liquid (I don't know if it had been cut down already as GSRstilez mentioned above), it didn't "hang" on the vertical surfaces where you get most bugs, so I couldn't get it to be very effective.
I use it and find it very good, diluted as per the bottle instructions, it takes off most bug remains without a problem.
