Optimum Polish vs Menzerna System???
Moe
Between Optimum Polish and/or Optimum Ccompound and Menzerna System, which one do you prefer in terms of ease of use and final finish appearance (depth/gloss/clarity)?
Have only used optimum polish, not compound and not done that much testing of it and I still like the menzerna system however optimum is a great product
The way that menzerna burnishes the paint, providing a swirl free dripping wet mirror finish with zero flaws is why I use it mostly although I have a stack of polishes and like them all for certain applications
Ease of use~Optimum polish i havent tried the compound but im still stuck on my menzerna. i just use the OCP after i use my menzerna.
OCP gives great resuls for me most of the time. But
I don't find it quite as effective by itself as the one-two
punch from Powergloss (or) IP, and FPII. But I do find that
it gives a nice finish almost comparable to FPII by itself.
If you got Menzerna Powergloss, Intensive Polish, Final Finish and PO85RD you will get a superslick finish.I´ll promise.
The mightytimmah and myself conducted an experiment the other day on my black SUV and decided that OP produces a shine that is equal to that of PO85RD. The difference that could have been there is not worth the extra money you pay for the Menzerna PO85.
JJ
The Menzerna line can produce the same results as the Optimum products. However cost clean up and overall ease of use makes me recomend the Optimum.
OP, doenst gum out that easy and sunny day friendly :D
IP, get dusty some time(depend the weather wise). I love both,but OP its my go-to.
Thanks guys. How about OP's ability to rejuvenate the surface like removing swirls, light scratches and oxidation? Menzerna line starts with aggressive compound like Power Gloss, can OPC or OPP performs the same? Many thanks.
OCP will remove oxidation as well as knock down swirl marks. The pad
used will decide how well and completely the swirls or oxidation are removed.
Admittedly, I have had some occasions where even with a wool pad, I
could not get OCP to do what I needed. In those cases, I will use PG, and
then followup with either OCP or FPII. If the Optimum compound does
as well as I am reading, then I'll have my solution in just two bottles instead
of four.
Menzerna is easy as ABC to clean up. Depending on how you do it, you may get some compound dust but that's easily removed with damp MF and comparing that to 3M line and so many others puts it way ahead of anything
I will say this though, the optimum polish is a very nice product and it's great having a product that can do multiple tasks, I really like it
However I don't go with one brand over another, I just buy them all and come up with a plan of what products to use on the particular car and it's hardly ever the same except the last couple steps - I always finish with either VM, RMG and YCW and sometimes all three in that order
Off topic a bit - what speed is best for new DP final finishing polish.
Guessing an edge classic white or blue pad
I like to use speed 4 initially, then 5 to finish it off.
But i think you could just jump to 6 without any problems, its a really nice and workable polish, and breaks down effortlessly.
Sorry - should have mentioned I use rotary, no PC's here in oz as far as I know.
JBM - your in a good area, not far from 4 star, premium auto care and autogeek.
SVR-I normally apply and work DP's FFP with a speed of 5. Seems much like Optimum or Vanilla Moose in that it stays wet for a long time. Really nice glaze.
Haha, ya i am near them, but it is easier to just hit "PAY" and wait for Santa in the big brown truck to show up hahahahahaha.
Arrgh - UPS.
I'm a USPS fan myself.
Thanks scottwax - love your work
Speed 5 - that's pretty fast with a PC correct?
Do you think that 1200 rpm or under with a rotary and final finishing edge pad work with DP FFP
