Need some advice
deft
I autox a bunch, and recently I've been having a real tough time getting the cone marks off my car, especially the black coloured ones. What products would you guys recommend? So far I have been having a rough time trying to use Klasse all-in-one.
After being able to remove some of the marks, I found that they left some scratches behind, nothing deep but definitely noticeable when looked for. What would you guys recommend?
Also, I was thinking of buying a PC, what model is recommended? Furthermore, can anyone give me a brief overview of the use of the different pads?
Anyway I really appreciate any help that can be given to me, I'm really new to all of this. Thanks a bunch.
-tim
I bet Poorboy's Professional Polish would work if it was able to clean up the Porsches mentioned in that thread.
I've only autox'd once, but when I did I was afraid of cone scuffs. Advice I read was to put a coat of wax on the day before or something.. I loved it, which is why I only did it once -- can't afford to buy new tires all the time :)
This is the PC that is recommended, or the 7336. Essentially the same machine, just different accessories and the 7424 comes with a 5" counterweight while the 7336 comes with a 6" counterweight. This page explains what a counterweight does and the difference between the two models. The pad that comes w/ the 7424 isn't supposed to be as good as aftermarket ones, so you'll probably want new ones right away.
This page, at the bottom, shows the difference between the various foam pads. Keep in mind that colors aren't necessarily consistent across manufacturers.
Thanks so much! I'll be sure to put some time away tomorrow to read through all of those. Anyway thanks for doing that :D, that's the most concise help I've ever received.
-Tim
