Need a good wax....details inside!
stang03
Okay so I have done the usual detail....
SSR2.5 with light cutting pad, SSR2.5 with polishing pad and so forth.....(the usual).....but I still have some spiderweb scratches that I can't seem to hide with 5 layers of Natty's blue.....is there anything I can put over the Natty's that might hide these small imperfections??
Thanks
Are you using a DA or rotary? I've used SSR2.5 with a cut pad on the DA to remove spider webs on cars with great success!! I agree with GSR on starting over and not filling. try Poorboys Pro Polish, the more agrressive the pad the more bite the polish has. then you can use SSR2.5 or PP with a finish pad then go right to your LSP.,or try FP11 or SSR1.
Chubs
I used all of these products with a PC 7424:
SSR2.5 w/ a polishing pad
SSR1 w/ a polishing pad
PwC Blue with a polishing pad
EX-P with a finishing pad
5x Natty's Blue with a finishing pad
What ya think??
GSRstilez said:
Yeah, go back to sqaure 1.
-Hi-Temp Extreme Cut
-Menzerna FPII
-Natty's
Done.
Although a lot of work i agree with sean. If you need to hide some defects/swirls mothers glaze/sealer it also keaves a wet finish and then apply your LSP.
