My QEW Method
AMP01
Member
Q E W Directions
By AMP01
What you will need:
1. QEW.
2. Your Favorite Quick Detailer (QD) Spray.
3. (2) 1 gallon, (or larger) buckets.
4. 1 micro fiber, (MF) towel or your favorite wash mitt.
5. 2 large waffle weave drying towels, (WWDT).
Here is how I use QEW, (Quick and Easy Wash).
1. I fill the first 1 gal. bucket with 1-2 oz. of QEW and soft water.
To this I add about 1 oz. of your favorite QD. I happen to use either Clear Kote’s quick shine QD or Meguiar’s Final Detail QD.
2. I have a second bucket filled with just soft water.
3. I use a MF towel dipped into the QEW bucket and squeeze just a bit of the water out.
4. I then, starting at the top of the car, gently clean an area aprox. 2’x4'. I then place the MF into the bucket with just the water in it to remove any debris I might have picked up. Before putting the MF into the QEW bucket again, I really squeeze the MF in the water and swish it around to really rinse it of any debris.
5. I wipe down the cleaned area with one large waffle weave drying towel. *(Use the first large waffle weave drying towel for the top half of the car and the second WWDT for the bottom half of the car)
6. Repeat steps #3, #4, & #5.
I am able to wash my 740i Sport in about 30-35 minutes, (not including the wheels/tires). By the way, I always keep my wheels and tires clean with daily wipe downs with QD and a towel so I rarely have to clean my wheels and tires.
Helpful Hint:
(If the car is really dirty, or for lower portions of the car and wheels that get really soiled, mix appropriate amount of Quick & Easy Wash with water and some of your favorite QD spray and put into a spray bottle & shake up to mix. Spray each really dirty section first and let soak before applying as stated above)
If my car is really, really filthy, I then use the traditional hose & bucket method. So far, QEW works really well for me.
Enjoy your washing!
Cheers,
