Mothers Step 1 and 3M SMR
Murph1083
If I use Mothers Step 1 (which is the polish (they call it a pre-wax) of the 3 step system) would it be over kill to use a SMR after that?
Actually if anything you should use them the other way around if you want to or think you need to.
In general, pre-wax cleaners all tend to be very gentle, almost non-abrasive products - even more gentle than a swirl remover. The reason for this is because they don't want Joe Sixpack to have any trouble using it, or even using it often if he does. By default, it's "safer" for them to sell a product that is too mild than too strong.
One thing I've liked to suggest in the past sometimes is to buy the Mothers 3 Phase, but substitute a real swirl remover or some other similar "pro" type product for the Step 1.
You can follow the SMR with the Pre-Wax Cleaner if you like - it'll just remove the oils SMR leaves behind.
PWC is an aluminum oxide based cleaner - very mild and safe. It's best at removing light oxidation, previous applications of wax or glaze, and helping to feather the edges of any marring. It's not as aggressive as SMR.
