Merlin
A Miracle Detailing
Mini-Review RYOBI High Flow Automotive Pressure Washer
Home Depot Pressure Washer 1.8 GPM Model # 1013019632
Pressure Washer Model Comparisons.
Ryobi website info Info:
"Ideal For Cars, Trucks, & Other Vehicles
Premium Car Detailing Accessories Included
1.8 GPM High Flow Rate for Optimized Cleaning
The RYOBI 1.8 GPM Automotive High Flow Pressure Washer is ideal for automotive professionals and car enthusiasts.
With a design that prioritizes an increased water flow of 1.8 GPM, this high-performance pressure washer achieves a deeper, more effective clean than other models.
The short handle design of the stubby trigger handle provides less vibration than a standard trigger handle, creating a comfortable one-handed experience while also allowing you to stand closer to your vehicle.
The specialized automotive nozzles can attach directly to the trigger handle and feature a dome design and protective overmold, enhancing durability and precision.
The 15° nozzle offers a concentrated spray for tough stains, the 25° for general cleaning, and the 40° for a gentle rinse.
The included foamer delivers thick soap to effectively clean dirt and grime. The included 40’ hose is 2X longer than a standard hose, making it easier to reach around your vehicle without constantly moving the pressure washer."
My thoughts.
If you're looking for an inexpensive pressure washer designed for washing cars. This one makes great foam!
The main requirement for making a thick foam is GPM, not PSI. To get good foam, you should have +/- 2.0 GPM.
However, when I've been looking at PWs with 2.0 GPM, they are usually around 4000 PSI or greater!
That'll peel your paint and your wallet! IMHO, for the price point, the Ryobi model 1013019632 it works great!
This unit is small (about the size of a loaf of bread), is electric (lower maintenance), and easily fits on my shelf.
I used the MTM Hydro PF22.2 Professional Snow Foam Cannon with the Ryobi 1.8 PW
I recommend quick disconnects for both hoses.
I purchased the M MINGLE Ultimate Pressure Washer Adapter set (Amazon $20)
This covers the garden hose in/out and the hose-to-gun in/out.
I believe it even has a swivel for the bottom of the PW gun.
I'm happy with the results of the Pressure Washer and the quick disconnects.
If you have any questions, please reply to this post.
