Meguiar's Unigrit
Marj
DavidB, posted some helpful info on filling chips and sanding down with the Mequiar's Unigrit block. My question is what grit is it? When I called my local paint and body shop supplier they asked me what grade did I want.:nixweiss
Grit is the size of the abrasive sand in the block, the higher the number the smaller (finer) the sand is, therefore less abrasive
For touch ups I use 1500, then 2000 (I could not find the 3000), then 3M SMR to eliminate any haze.
Belicoso
Are you saying you have the Mequiar's Unigrit sanding block in two grades of 1500 & 2000?:nixweiss
