Hi guys,
Sorry for the delay in updating this. Had the flu earlier this week so just finally got to work on it yesterday. To answer a couple questions, I'm using a 7424XP and the DA MF system with 5" pads.
Kevin was good enough to chat with me a bit and give me some tips. So yesterday I spent a good seven hours polishing, and still was only able to remove about 1/2 to 2/3 of the swirls. Keep in mind, the swirls weren't horrible to start with. I probably spent two hours on the hood alone. I tried varying speeds, and noticed that I got the best results on the highest speed setting with enough pressure to only get only 1-3 pad rotations per second. I experimented with using more and less product, with and without supplemental wetting with distilled water in a spray bottle. To it's credit, the MF system DID make the paint look better. Less hazy and the metallic flake coming through more. It really does look great, until you find a reflection of the sun in it and see the swirls. Not something you'd notice from ten feet away.
I probably should have gotten some M105 and tried it, but this has been going on for a week and no one stocks it locally here, so if I order some then the car's gotta sit for another week before it's finished. Yesterday, after polishing, I was able to get one coat of the finishing wax on before my back gave out on me. Car's still sitting in the garage and will get (hopefully) another coat tonight, then maybe another on Sunday.
I'll try the M105 later this fall when it's time to do it again.
I have no doubt that the system is a good product, and that others will and have gotten great results, but the clear on my S8 must just be too much for it; or too much for me and my lack of experience :hmph:
Thanks to everyone for their help and suggestions.
-Rob
