Makita 9227C power cord problem any others?
Dairyman
I bought a Makita 9227C about 3 months ago it has been great besides one problem the power cord...
every time that I use it the cord "wraps" around itself and tangles up so today was the final straw right at the base where the wire connects to the machine it ripped inside now I have to hold it down to get any power.
I am going to get it fixed or warrantied but was wondering if their are any upgrades to stop this from happening again?
Switched back to my dewalt 849 use it the same way (actually much harder on it) and never had a single problem
has anyone else experienced this the Makita was a good amount more than the dewalt
I suggest buying a 25 foot 16 guage extension cord and replacing your existing Makita cord with it. Wire it directly into the tool.
Yes! Look for one that's very flexible. The problem with the Makita cord is that it breaks at the stress reducer - that rubber piece that comes off the back of the tool. It's too stiff.
I wrap the cord with electrical tape at that junction but still, it's just a matter of time till it goes. Small enough price to pay for a machine as light and quiet as the Makita. Still, if they keep that stuff up, Hitachi makes a really good polisher too, I may buy one of those and try changing out the grease in the head for synthetic to see if it will run quieter. That was the only problem I had with the two of those I've had.
Robert
Mine went bad a few weeks ago. I just hacked off a few inches and re-wired it. :xyxthumbs
I had to replace my cord after about 1.5 years of use. Had the tool repair shop replace it with a 18' cord that was for a Porter Cable drywall sander. The guy at the tool shop advised against using an extension cord as a replacement. The power cables have a lot of fine copper wires twisted together that allows the cable to be flexible. An extension cord will have thicker less flexible wires that will actually end up breaking sooner due to all the flexing the cord under goes.
This is a very common thing with Makita's and always seems to happen at the wrong time! I have it down to a science now and can have it completely rewired in less than 5 minutes. More annoying than anything, but at least it's a quick & easy fix.
Lots of electrical tape around the cord nearest the machine will help it last longer. I replace all the protective tape on my unit every couple months.
I'm going to go with this answer. In fact, I'm going to order two of those cords and install them.
Thanks.
Robert
I did just this and couldn't be happier with it. I'd highly recommend it! :up
Best advice given... Did this to mine about 3 weeks after I bought it. And now 4 years later it's still just as good as the day I did it.
what kind of extension cords are you folks using? I had this happen to me at the wrong time once and had it fixed. Slowly but surely it looks like the cord is getting funky again so i would like to be prepared with the right stuff for the repair if needed.
Like Rick, I have it down to a science. It almost has become kind of a pit stop for me. I will tell you though that on one of my polishers the cord has become kind of short due to the number of times I have had to cut it done. For some reason I prefer the shorter cord.
I wish I ran into this a few months ago... I hope replacing the cord is an easy as you guys say.
Makita will NOT warranty it. They will say you overstressed the cord. Ask me how I know and I'll refer you to the money now gone from my bank.
I just went to home depot and grabbed a 25' 14 gauge (black and red) cord. Like rick said it just takes a couple of minutes tops to replace it. Pretty straight forward and easy to do.
