Leatherique Rejuvenator Oil?
PGA2B
How much do you use and how long do you leave it on?
I have heard 24 hours but what about when the sun goes down?
As for how much I heard to "Slather" it on?
I am doing my interior of my V. I also have a leather wrapped dash and console. Should I also do those?
If you are going to use it you can use it on any leather surface.
I would say about 6-8 ounces, a nice even, thin coat over all of the surfaces. 6-8 hours is plenty IF you are able to get the temperature above 90 degrees in the inside (higher is better).
depending on leather condition too right?? well i had it for like 10hours. My seats were clean to begin with but i just thought the longer the better . plus the temp was like 95-98 so took advantage of that. and i am glad with the results if you follow the correct instructions. :
Yes the entire interior is leather wrapped with baseball stitching. It's an STS-V.
It looks like this:
Not to defer from the advice on this site but the leathique site has a lot of instructions processes and what you can use it on
I just used it again today. It can be difficult to use if you don't do it right. The first time I used it I slopped it on real thick and didn't leave it on long enough, consequently it was a bear to remove. Today I applied it so that the seat was covered but not dripping down vertical portions. Used a foam paintbrush. Left it on from 8 until 5 with windows up, and car in sun. Was about 78 today. It was tacky at the end but mostly dry. Came off fairly easily but took two rounds of spraying with the cleaner and wiping with towels.
Towels were filthy when I was done. I have never used anything that works this well on older leather.
Hello Todd Will Leatherique Rejuvenator penetrate into Pigmented, or what's sometimes referred to as "painted" leather?
I'm unsure how effective this product would be on such leather surfaces?
Many vehicles today (such as my Tahoe) have pigmented leather. Mark
owned a 12 ctsv black diamond with leather myself. i used leatherique a couple of times on it. dont put it on too thick for sure but check back to find if some spots need more product. i licked to massage it a bit as i applied it with a mf sponge. everyone talking about these 75-90 temps make me envious. i live in oregon and it almost never gets that hot so i would use the heater too and pick warmer days. i also found that leaving it on for much longer was even better 24 hours at least. i have used it on lots of other cars with painted leather type seats and it works well there just that the end product doesnt seem as glove soft. the price of Leatherique makes it kind of special and used sparingly but it rocks.
I have used Leatherique twins many times. For the Rejuvenator Oil I like to use spray head to spray it onto the leather and then work it in with a MF applicator or a foam applicator. I continue to apply and work it in until it does go in anymore. I then let it set for as long as possible in the sun or with heat. I like to let it set 24hrs or more if possible.
The seats in my Acura are finished coated leather. And the Leatherique twins have always worked well.
I use the Pristine Clean I the same way. Use a sprayer and apply it to the leather. Then use a MF towel to clean everything up.
Thank you Troy for your answers.
I think for the mean time, I will continue to treat with what products I have on hand, such as Lexol. I think I have a small sample bottle of WG, or Pinnacle product on hand, which will serve for one good use.
But when I do order more goodies again in the future, I will seriously keep Leatherique in mind.
My seat have always been kept clean, I'm quite fussy like that, but what has happened over the years, is the driver's seat bottom is starting to show small cracks in the leather. Mostly on the left bolster.
And at these cracked areas, the leather looks darker that than the grey finish, and sort of looks like ass. No doubt caused by both this seat being used the most, and an eventual drying of the leather also.
The Leatherique I'm hoping will arrest any further cracking, add moisture-suppleness, but I might also need a correct color dye to apply carefully to hide these cracked areas from being quite as noticeable? I think this would help mucho, along with the Leatherique two-step process.
Mark
You should only need thin coat for the product to do the trick. Here are a couple guidelines to get the most out of it. I have years of professional experience working with leather in vehicles and furniture.
1. Apply a thin coat. You don't need to slather it on thick.
2. Do the job on a warm, dry day. Humidity and moisture are your enemies.
I haven't used it, but "oil" and "leather" makes me nervous, I always thought you don't want oily products on leather
Frankly you don't need to use anything on automotive leather. It is called "finished" leather which means it is coated with a thin layer of vinyl, and NOTHING penetrates it. So applying all kinds of leather products on your leather cars seats is a complete waste of money, if you are looking for protection.
However, if you like shiny seats and leather smelling seats, go ahead. Some products do smell nice.
That said, if you do have unfinished leather, like some very high end European luxury cars, then leather products are helpful, much the same as we apply leather products to our horse saddles, etc. All I use on my vehicles seats is a mild soap and water to clean them. My car is new, however my wife's is six years old and the leather looks new, and has never been "treated" with anything.
Mark,
The answer is yes/no/maybe...
Starting with no... If the pigmented coated (painted/protected) is brand new then it is likely that none of the Leatherqiue will penetrate the finish...
Yes... The pigmented coating will develop microscopic tears and pores over time. The constant flexing of surface will accelerate this wear, which does expose the leather hide underneath... Also holes in the leather, such as near the stitching, provide a direct path to the hide underneath.
Maybe... It really depends on the age and condition of your leather as to whether leatherique is going to offer any benefit. If the car is lightly used, sits in a garage, and is less then a year old, leatherique will offer little benefit.
On the flip side, if your car's leather experiences heavy traffic, temperature extremes, and daily the leatherique treatment will work extremely well.
I am very interested in this topic. Honestly, I hate leather seats. They just don't remain "new " enough looking for my liking. They are hot and sticky in the summer and cold in the winter. I have used many traditional leather products on the black napa leather seats on my BMW much more frequently than recommended, and the drivers seat still shows signs of wear. I would much prefer a nice velour / leather mix like BMW's "M cloth" they used on some European M cars:
My Nissan Pathfinder has 103k on the odometer. It has velour seating. Even the driver's seat shows little if any signs of wear, even on the bolsters:
I've done some Internet research, and opinions on coated leather seem to be divided. At this point, I'm just cleaning and protecting them with CarPro Fabric and Leather, as that leaves a protective coating.
My question about the Leatherique system is:
1. It seems to clean very well, does it leave protection behind against UV (convertible) and the mechanical abrasion caused by sitting in the seats?
2. Can you use a "leather coating" like L1 or Fabric and Leather after the Leatherique process, or will you be "cleaning out" all the Leatherique that soaked in over your 12-24 hour dwell time.
I like that Todd gives specific strait forward factual and knowledgeable answers and doesn't give an answer that is pretty much common sense. Thanks Todd!
I used the leather rejuvenator, left on overnight. Then cleaned with pristine clean, and noticed that the sheepskin seatcovers had tranfered some dye on the edge of passenger seat. After the clean up the dye transfer is still there. Should I repeat or try something different? The rest of the surfaces are beautiful. Maybe better than new because it seems softer.
1. My understanding is that the Presitine Clean does leave behind some UV absorbers and a fine coating that will protect against mechanical wear.
2. The oils are absorbed into the hide, not the pigmented/painted coating. You can still use a sealant on top, but I would lightly wipe the surface with a diluted APC, such as BLACKFIRE prior to application (or use the companies recommended cleaning procedure).
Would this be recommended for a four year old that is left out in the sun a lot? I don't know if it's my imagination but it feels as if my leather has become super hard since the original purchase?
I already used some leather master rejuvenator oil, not the biggest fan.
